Need a racetrack with stands and infield
thenotoriousjedthenotoriousjed Posts: 397
edited January 2017 in Product Suggestions
I was looking and can't find a racetrack to use for Daz Studio. I've found a bunch on other sites like turbosquid so there must be a market.
I had a few thoughts about doing renders at a race track. Cars on track, fans in stands, maybe a pits area or garage. The best I've found to use that I had was the reactrack that comes with the little ones play area.
Post edited by thenotoriousjed on
  • nonesuch00nonesuch00 Posts: 18,765
    You're best shot at a reasonably price race track will be to download Unity 5 & signup to use their Asset Store (free) and then search among their race tracks. There are even tools to build your own race tracks that you can buy.
    Some are cheap and some are expensive and cheap doesn't necessarily mean bad quality and expensive doesn't necessarily mean good quality.
    Then you'll want something like the DAE export so you can export the entire Unity scene as a single object (although that might already be the case). it is FBX format that is most commonly used in Unity scenes.
    Once you get the scene into DAZ Studio you can then edit the surfaces. You'll probably want to convert to iRay PBR as that won't export out of Unity should you buy a racetrack already configured using their standard shaders (which is PBR).
  • Oh wow. How did I miss that. I hate trying to search on Rendo. Thanks Charlie, this looks like what I wanted.
