DS 4.9 Update - Installed Dynamic Clothing Control Update - Not Showing Up In Pane List - *Fixed*
TJohn
I installed the update for DS 4.9 this morning, then I installed the update for Dynamic Clothing Control. The DS 4.9 works great, but the Dynamic Clothing Control doesn't show up in the available pane list. Is there anything I can do to fix this?
Post edited by TJohn on
Are you sure DS had finished installing before you isntalled the control plug-in?
In DS look in help > about installed plugins. Is it shown there? If so, is it shown as active or do you need to reenter your serial number?
Slightly different experience ... DS4.9 (installed via DIM) mad the bought DCC (also DIM installed). Both upgraded via DIM.- DCC tab disappeared from Posing|Shaping pane ehere it had been (placed by me) before the upgrade. DCC appears in installed plugins list and panes/tabs list. Once opened (via Window> Panes (tabs) it re-dcoked where it had been before when I dragged it across.
Thanks Richard and Charlie. It needed the Serial# entered again and a restart. Changing the Header to "fixed". More people will need this info I think.
