Where to extract Genesis 3 Starter Essentials?
Where do I extract Genesis 3 Starter Essentials zip file?
I downloaded it manually.
Will it also work with Daz 4.7?
The folders in the Content folder in the zip need to merge with the equivalent folders in your content diectory - /DAZ 3D/Studio/My Library/ or whatever you use.
The base figures should work, Iray materials won't, I'm not sure if there's anything else that requires a later version.
