Toon Square IRay Conversion
GreybroGreybro Posts: 2,603
edited January 2017 in Product Suggestions
So, I just picked this up and it works and renders fantastic in 3Delight.
http://www.daz3d.com/the-toon-square
I did my normal uber base conversion to IRay settings and for some reason, it just spins and essentially never renders in IRay. While it isn't really that big of a deal to make my character in 3DL versions, it sure would be nice if I could find a way to make this renderable in IRay. Has anyone had in luck with this?
Post edited by Greybro on
  • I've successfully rendered the Toon Square in Iray. The problem you're probably encountering is with memory. The thing is huge. It used every byte of my 16GB of RAM, and a little bit more beyond that - if not for the latest MacOS's memory management and the fact that my virtual memory is on an ultrafast SSD, it probably would have been too much. Delete the parts that aren't relevant to your shot before rendering.
  • GreybroGreybro Posts: 2,603
    I suspected as much.  I only used the park section in the shot but even that depleted the memory.
