Lost morphs
I am using Genesis 3 and have spent some time adjusting face, head and body morphs. However I opened my saved project today and fonud the morph adjustments I had made had disappeared.
I went to shaping to adjust the morphs again, biut on closer inspection noticed that all of the dials I had adjusted earlier were still set to the positions I had chosen, for example - forearm size = 65%.
Do I need to somehow save out the morph settings?
  • Do the morphs kick in if you tweak the slider slightly? A few people have been having odd issues along these lines, though not quite the same in each case.
  • Thanks for your suggestion Richard, but tweking the slider made no difference. I had to enter Parameter settings and utntick "use limits".
    I then adjusted the slide to the morph setting. It hasn't happened yet but I am expecting the body part to double in size when i open the figure.
