question about loading victoria 4.2
Hi there, everytime I load V4.2 I get the two following messages.  It's as though v4.2 is not really loaded in the system.  Anything I can do to make sure that I don't get these messages??  Any info appreciated, thanks.
  • KaribouKaribou Posts: 1,325
    Assuming that V4.2 actually appears after you accept the messages, then this is totally normal.  It's the PowerLoader adding supported morphs to V4.  If you want to prevent this from happening, you can do what I did --
    1) Load V4 to an empty scene.
    2) Accept the PowerLoader messages.
    3) Save her as a scene subset to one of your DS content directories (not a Poser directory.)  This will make her a .duf file.
    4) Select THAT V4 when you want to load her into a scene.
    The drawback is that if they ever update V4 (which I have no idea why they'd do) or if you bought new morphs for her, you would need to re-load and re-save her.
    This is just my approach to the subject!
  • Thanks Karibou, yes, V4.2 appears afterwards.  I just wanted to make sure that this wasn't abnormal behavior.  If it's par for the course, ok.
  • Digital Lite DesignDigital Lite Design Posts: 728
    edited December 2016
    PowerLoader allows you to add morphs to the character when it loads into the scene and it is normal behavior.  You can do the following:
    You can rename the PowerLoader scripts in the folder containing the CR2 for V4.  Preface with _ or something simple like that.  You can remove later if you want PowerLoader to work again.
    This is a much easier solution than trying to make sure your saved V4 is up to date with your morphs, etc...
    Post edited by Digital Lite Design on
