DISPLAY export not right
I am trying to EXPORT the WIRE FRAME UNFOLDED MAP! of my charters HEAD and what is EXPORTED in NOT the map I am exporting!
SEE ATTACHED.
The Color one is what shows up under the UV View in the vertex room and when I export it what I open up in photoshop IS NOT the map I exported
  • RoguePilotRoguePilot Posts: 239
    Yes it is,
    You've either got some verteces hidden in the UV view or you're not displaying all the regions.
    The export option will always export the whole UV map.
    The texture will not be included.
  • edited December 1969
    Yes it is,
    DING DING DING your right! I forgot about my hid poles! Thanks guy
  • edited December 2012
    THANKS man that was it!
    BUT also I have a map in the back and have some BLACK in it so the geometry on top of that AREAS IS HARD TO SEE. IS there anyway to say TUNRN off the MAP in the UV view area so one can more easily mess with it. Instead of going to the SHADER room and say dump the UV map and givee it a color.. BUY even when I do that it doesnt work all the time.
    I can go and dump the UV MAP and set the COLOR channel to say whites but then I go back to the UV MAP room the MAP is still there!
    Post edited by richard.chaos_91798ec102 on
