2 things...
There are a couple of things I want to know about...
- why wasn't the DSON Importer not intended for Poser 10? I was looking forward to start working with later model figures (perhaps Poser 11?).
- (check the Art Studio area for 'genderless model') are the male morph dials available with later female models (Genesis)? That option is proving useful, as I'm workiing on creating androgynous beings with the V4 figure, along with The Girl 4 and Aiko 4.
The DSON Importer works with the last few versions of Poser, including (as far as I know) Poser 10 - it certainly works in PoserPro 2014, which is the same generation.
Poser 10? The Daz installer wouldn't let me install it, its not a required program or something, according to the message that came up.
Was this with DIM? Had you set Poser 10 up as an available application? Click the gear icon at top-right to open preferences, then go to the Application tab - if Poser 10 isn't listed click the + button, enter the version details, then click the ... to set the path.
Yes, it was with the DIM, I'll see what happens.
DIM seems a bit confused about Poser versions. I had to tell DIM that my Poser 11 was an earlier version before it would install the DSON importer.
I installed mine via the manually downloaded file in my product library...
http://www.daz3d.com/downloader/customer/files/prod/14897
While you may not have problems, I found some geometry issues that were solved by going back to to an older beta version. If you have any such issues, the beta may be in your product library...
http://www.daz3d.com/downloader/customer/files/prod/16190
Actually, thats what I've done also. I just need to install on the system at somepoint, when I've got some time.
How can i download file DSON Importer for Poser? I do not see where it can be taken, nor on the page https://www.daz3d.com/dson-importer-for-poser.
