Body mesurements and morphs
Hi all,
i need your help. I need to change and customize the measures of male avatars.
I bought the plugin measure metric but i'm not able to use it ( mabey i bought it wrong)
Can you give me some tips? how can I change the measurements?
Thanks a lot,
Erisa
You need to use the Figure Metrics part of the pack - in People>Genesis # Male>Measure Metrics you will find a pose preset and wearables preset to set the figure up, then in Scripts>Utilities you will find the Figure Metrics script which opens a dialogue showing all the measurements. If an item has a check box you can check it and enter a desired value, if not you need to use the Advanced tab to assign a property to the measurement (a morph or transform that will chnage the emasuement) to get a check box. Once you have your properties checked you can click the Accept button and the script will try to adjust the selected properties to get the desired values.
Hi Richard,
I was wondering, when your team developed measure metrics, were there specific morphs/transforms used for specific nodes? I would like to use all of the nodes to create G3F characters but I am oblivious as to which nodes goes with which morph/transform... Could you clear that up for me please?
Well, first I was not a developer for Measure Metrics (or anything else for that matter). The initial choices of morphs for Figure Metrics should give you a starting point, I would imagine that Rob didn't want to add too many dependencies on other products by adding in morphs from multiple sets. I would advise caution in adding (or at least in activating) multiple morphs as you risk slowing each iteration down, and also risk setting up conflicting effects which may reduce the effectiveness of the process.
Thanks for clearing that up.
Cheers
