A bug very strange
starkadh
Hy, guys...
First of all, Merry Christmas' Eve.
So...
Every time I open Daz3d or save a render, every picture - gif, jpg or PNG - is doubled in 2 files. And the second file is very small and with the world Icon in the title.
For example: If I have 4 pictures on desktop, I save a rendering done with DAZ3d and the result will be 10 images! 4 original pictures, 1 saved rendering and 5 smaller and useless copies.
This is not a big problem... but it's annoying. What I can do to fix it?
that is the thumbnail image.
This will happen only if the folder you are saving to is set as a Render Directory folder - since I find it annoying, and don't use the Render Library pane, I have my only Render Directory set to an empty folder that's out of my way. You can do this from the Render Library pane option menu - the lined button in the pane's top corner - and highlighting the default location, then clicking Edit and picking a folder you don't use for images. Of course this will break the Render Library pane, so don't do it if you use that.
OOOk, thank you ^_^
