Problem with lips
rickfoxxx74331700rickfoxxx74331700 Posts: 186
Is it possible to fix this?
It only appears when I rendering...
  • ghastlycomicghastlycomic Posts: 2,531
    Are you sure you have the right UV map set for the texture?
  • rickfoxxx74331700rickfoxxx74331700 Posts: 186
    I use Poser. Where I can check if I use right UV map?
    That I don't know, I don't use Poser. What figure and texture map are you using?
    edited December 2012
    I use Victoria 4.2 with Ariana Elite texture.
    Post edited by rickfoxxx74331700 on
  • Richard HaseltineRichard Haseltine Posts: 108,488
    Does it happen only with those textures? What are your render settings?
    No, it happen with all textures. These are my render settings:
    708 x 592 - 87K
  • jean_paul_baconjean_paul_bacon Posts: 55
    I'm not an expert but, it seem that the shape curve of the texture it the same as the light shadow (crescent shape).Maybe the origin of the light point should be modified ... This is the first thing i should try, as an unexperimented guy i am ! did you tried unusing displacement map ?
    Post edited by jean_paul_bacon on
  • BejaymacBejaymac Posts: 1,949
    Try closing her mouth a bit, as it looks like the inner and outer parts of the mouth are merging and causing poke through.
    You might try unticking Use displacement, which was my suspect, but if it's all texture sets I doubt it's the that in which case it is probably a case of needing to push the morph a little less as Bejaymac suggests.
    How can I disable the displacement map?
    It gets smaller according I closed mouth, but I need the mouth very open.
    The option to enable displacement maps is checked on the right in your screen shot of your render settings - though it doesn't sound as if that's the issue, unfortunately.
    True, this is not the cause of the problem.
    Try, just for a quick test, unchecking Subsurface Scattering...
  • JaderailJaderail Posts: 0
    Am I the only one who knows what that pose is for? Not a fan of doing that in 3-D.
    Of course I could be wrong, but as an ex-artist that did those I don't think I am. I never had this problem at that time.
