Trasparency in DAZ studio
Hello everyone!
Does anyone knows how to change object's trasparency degree? For example, how to make an object half-transparent? I mean in viewport first of all, not in render.
Hello everyone!
Overlapping transparent surfaces, which you are bound to get with an object, do not preview well in most cases. Selecting all of the surfaces on the model (in the Surfaces pane) if it is using the Daz Default shader adjust the Opacity value.
Select the objekt in your scene tab, than open the surface tab (Windows-Panes Tabs-Surfaces( Color).
There scroll down to opacity strengh. With the lever you can adjust the transparency. If you apply a Shader on the object, you have more options to make changes on the surface.
Hope this will help you.
