I found clothes for Victoria 4 but how to use them with Genesis 3?
Hello
I downloaded daz studio 4.9, and why do not I find Victoria 4 ..?
Thank you
Hello
Thank you
Clothes for V4 will fit V4. She is a stand alone figure, not connected to the Genesis lines of figures. Older technology. There are products available which can help you to exchange clothes between generations. If you want to experiment with V4 then you will need to buy her. http://www.daz3d.com/catalogsearch/result/?q=victoria%204.2 Daz Studio comes with the Genesis figures, Genesis , Genesis 2 and Genesis 3 included. The compatability Matrix here http://www.daz3d.com/compatibility-matrix will maybe help you understand what can be used with which figure.
Load Genesis and the clothing, fit the cloting to Genesis and use AutoFit to convert.
Load Genesis 2 Female and fit teh covnerted Geensis clothing to Genesis 2 Female, using AutoFit to convert
Load Genesis 3 Female and fit the converted Geensis 2 Female clothing, using AutoFit to convert.
Thank you Chohole
1/ If I understand correctly, the clothes for V4 are not compatible with Genesis and Genesis 2 and 3?
2/ I would like to buy a bikini for Genesis but how to use it because there are several folders?
Thank you
See Richard's post above yours.
Yes I tried to understand but I do not arrive ..
What is "autfito"?
If you fit an item of clothing to a figure it was not made for (assuming the figure has metadata to say which it is) then the AutoFit dialogue opens, allowing you to set the figure the clothing was originally made for and optionally the type of clothing. Daz provides each version of Genesis with clones for the previous generation (so Genesis has Victoria 4, Michael 4 and Kids 4; Genesis 2 has Genesis and so on) as well as, for Genesis 2 and Genesis 3, clones for the same geenration's opposite sex. Those clones are what is needed to convert a piece of clothing (and theya re the source of the list of original figures in the AutoFit dialogue) so without buying anything else you can go in steps from Victoria 4 to Genesis 3 Female (or Male). There are add-ons, such as the Wear Them All sets, that alow you to skip several generations (which should give cleaner results) but they are not essential.
