Lady of the lake for Ninive question
TSasha Smith
in The Commons
Why does lady of the lake texture for Ninive 6 need Ninive 6? Can I use the texture on any Genesis 2 female? I do not think I have a way to put genesis 2 female textures onto Genesis 3 female.
I want to use this texture on different shapes than just Nineveh 6 and it looks like it is a possible freebie choice for today.
The product description indicates that Lady of the Lake uses the Ninive UVs so you would need to have Ninive 6 for the UV set to use these textures on G2F easily. I have not tried converting textures between UV sets with the Genesis 2 products, but I believe I have seen some instructions for doing this with other programs in forum discussions here.
So all I need to do is have Ninive installed to have the textures work on other shapes?
Yes. As long as you have Ninive 6 installed, the texture should load the correct UVs and then you can apply any G2F shapes to the figure.
You can use the texture on any G2F.
Edit. Didn't see Jonathan B's answer. He is right about the UV's. Stephanie UV work ok for the face but but not the hands some of the others work ok for some areas but you would have to be really creative with pose and clothing to get a good shot.
Haven't used Lady of the lake on Ninive and forgot I had the UV.
Re-edit. Taking me forever to type tonight.
Two quickies of the LotL texture on Bellatrix with the Steph6 UV showing the proplem spots and one with the Ninive UV.
(Had to redo them with clothing LOL 3.30 in the morning).
I've used it on G3F with Cayman's Legacy UV products (I think the one for G2F is over at Rendo.)
This is a WIP, trying to create Nightshade, my toxic superhero, with that skin on V7.
