How do I delete a Surface?
barbultbarbult Posts: 26,387
After using the geometry editor to split a surface into two new surfaces, how do I delete the old empty surface I have left over in the Surfaces Tab?
  • barbultbarbult Posts: 26,387
    Oh, I thought I was posting in the Commons. Can someone move this for me, please? Or an answer here is fine, too. :)
  • fixmypcmikefixmypcmike Posts: 19,703
    Moved to the Commons, as requested.
  • Richard HaseltineRichard Haseltine Posts: 108,637
    In the Tool Settings pane, select the surface (if it isn't) and then right-click and select Remove Selected Group(s).
    Thank you, Richard. It worked.
    For my future reference, I'm documenting the exact steps I did here:
    I selected my item in the Scene Tab,
    selected the Geometry Editor tool,
    opened the Tool Settings pane,
    set Target Group to Surfaces,
    selected the surface I wanted to get rid of,
    right clicked and selected Remove Selected Group(s)
    saved my item as Support Asset->Figure/Prop Asset
  • stitlownstitlown Posts: 310
    Hi Guys. My problem seems a little different.  I have imported several shed loads of stuff across from Vue, which I abandoned some years ago.  For some reason, some items are showing up having multiple surfaces in the "surfaces" tab, but in the geometry editor I have just one surface (the one I want) and one "default" face group.  Consequently, I don't appear to have any "surface" with no attached surfaces to remove.  Any hints or clues??
    Thanks Lx
  • Please post a screenshot of the two lists of surfaces.
    Hi RIchard - I think I solved this with a different workflow through some other programs that mean the issue does not appear to be showing up any more.  Thanks. Lx
  • KaribouKaribou Posts: 1,325
    Would be interested in your workflow.  I've had issues with Vue to DS, too.
  • nonesuch00nonesuch00 Posts: 18,774
    edited January 2017
    It seems the Geometry Editor Tab is missing in the newest DAZ Studio Public Beta. Also, I created a new surface with no geometry assigned and it shows in the Surfaces tab but I see no way to delete that surface.
    What I've like to so really is use a already existing surface to create a 2 new surfaces that divide the existing surface in two and then delete the existing surface.
    ....ah, I found it again...it is Tool Settings
    Post edited by nonesuch00 on
    I found it but when I select the flippers to assign them to 'Create Surface from Selected...' the new Surface will get created but it will not have the flippers faces I selected via the existing 'Face Groups'
    992 x 578 - 111K
    OkieDokie...well highlighting the Face Groups (and so on) I've found doesn't actually select them for that you must click the + sign to the immediate right of the name & the minus to to the right is the + sign to deselect & then those selected Face Groups can be assigned to a new Surface. I knew it was easy.
  • edward_087c136cedward_087c136c Posts: 1
    edited December 2020
    how to remove eyelashes from genesis 3
    • tools > select ‘surface selection’ > in the viewport select the eyelashes
    • tools > select ‘geometry editor’
    • windows > panes > select ‘tool settings’
    • in the ‘tool settings’ pane set ‘target group’ to ‘surfaces’
    • scroll down to the surface you selected (Eyelashes in this case)
    • press the + symbol beside ‘Eyelashes’ in pane (the eyelashes in viewport go red)
    • right click on the eyelashes in viewports > Geometry editing > click ‘delete selected polygons’
    Post edited by edward_087c136c on
    • right click on the eyelashes in viewports > Geometry editing > click ‘delete selected polygons’Exe
     Exactly what I was looking for. Thank you!
