Using G3F poses on G3M
AngelAngel Posts: 1,204
Quick question. I have never attempted to use G3F poses on G3M or visa versa in fear of screwing up the joints beyond repair... In the past using V4 poses on genesis resulted in an ugly mess and I never tried that ever again... How likley is that to happen with G3?
    edited December 2016
    I use one genders poses on the other all the time and haven't noticed anything weird ;).
    Laurie
    Post edited by AllenArt on
  • isidornisidorn Posts: 1,601
    It mostly goes fairly well. Some adjustments are usually required, but when isn't it? :)
  • AngelAngel Posts: 1,204
    and while were on the topic. how about genesis 1? i liked a lot of G1 poses
  • xyer0xyer0 Posts: 6,510
    Dont know about Genesis 1, but I use Genesis 2 poses on Genesis 3 all the time, and I have not had to use my pose converters yet.
    as long as it dont break my actor... i dont mind adjusting. i adjust anyways even if it lands perfectly i always do something to my poses to give it more Zaz
    I have never had any luck using G2 poses for G3. In fact I'd say they don't work at all.
  • Aside from having to adjust broken as all hell spines on most poses, I've used G3F poses on G3M with no issues whatsoever.
    use a pose converter since G3 figures have a different structure than the other generations figure
    Laurie
    Same here. Just try it and see how it works, shouldn't hurt anything and as long as you saved before it, you should be fine.
    G3F <-> G3M I've tried some and no problems so far. I've tried G2 on G3 and some cause problems & others not. None translate exactly. You just have to try them to find out in they are acceptable.
