N.G.S. Anagenessis II - Revolution [Commercial]
1222325272843
  • unknownmystery445unknownmystery445 Posts: 414
    edited December 2016
    Hi @unknownmustery45, thank you! I'm an art director, so I've been using photoshop for years! I'm new to DAZ, though. So far, I'm loving it but I still have no idea what I'm doing half of the time. So, I end up rendering things and then finishing the details in photoshop haha.
    Sadly, I haven't made any tutorials D:, but you can always check the ones over at DeviantArt: http://www.deviantart.com/browse/all/?section=&global=1&q=photoshop+hdri+tutorial.
    I truly wouldn't mind sharing the altered skin with the community, but I'm not sure if it's allowed (since I simply tweaked Antfarm's skin files). Perhaps someone knows how to go about it or what the rules are?
    Oh I hope you can share them also if you have other edited skin maps :) you're really good but I think if you make tutorials it would even be better! :) since you'll help people in understanding photoshop :) by the way I've searched the hdr tutorials and I've seen that you need three images with different exposures right? How did you do that with a skin map? Did you just adjust the contrast or what specifically did you do? To get those 3 images? Also how did you add bumps in the scars or wounds? :)
    Post edited by unknownmystery445 on
  • FenixPhoenixFenixPhoenix Posts: 3,181
    @unknownmystery445,
    1. To create the scar, I just painted highlights and shadows and added a grungy texture to it (I just go by feel, since I paint a lot too). Here's a tutorial on how to create scars in photoshop which you may find useful: https://www.youtube.com/watch?v=P-jIkpkc2Nc If you're good at painting with a tablet, then I suggest checking out this amazing brushes: http://nataliehijazi.deviantart.com/art/APs-Brushes-Skin-Textures-256231267
    2. Photoshop CC actually creates bump maps automatically for 3D things. Here's a video tutorial for it: https://www.youtube.com/watch?v=_3CG-lzy0RA
    3. For the HDRI I would suggest checking out some of the free actions here: http://www.twelveskip.com/resources/ps-actions/922/12-free-hdr-actions-for-photoshop That way you can tweak the results to your liking afterwards. If you don't know how to use actions, you can check it out here: https://www.youtube.com/watch?v=B_ydHcDRJ-c
    If needed, perhaps we can create a thread for more of this explanations. That way we don't take over this one XD.
    Post edited by FenixPhoenix on
  • @unknownmystery445,
    Alright thank you for this! I'll just message you when I have further questions :)
  • Hi @unknownmustery45, thank you! I'm an art director, so I've been using photoshop for years! I'm new to DAZ, though. So far, I'm loving it but I still have no idea what I'm doing half of the time. So, I end up rendering things and then finishing the details in photoshop haha.
    No, you can't share a tweaked version of another person's textures - unless they give prior permission in a readme.
  • jardine said:
    I love this character.  Who is she?
  • MJW said:
    D-Z, I would be happy to proof-read the manual for you either in advance (bit soon) or after first issue if you like.
    One question struck me yesterday. How do you remove Anagenessis when it has been applied?
    I've had to select all surfaces and reset the shader to the original default version - e.g. DAZ Default, omUberSurface, etc. Then re-apply the original MAT texture.
    That character is one of my favorites:  Draupadi
  • Can I just ask does this work with the HD Add on morphs for characters? Or does this eliminate the HD Add on when used?
  • KhoryKhory Posts: 3,854
    It should have no effect on the HD at all.
    So it'll work with it? And enhance it?
  • grinch2901grinch2901 Posts: 1,247
    Addressed this in another thread but in case others see the question here, here goes.  HD morphs add detail to the model itself (the mesh). They add wrinkles, creases, pores, scars, whatever the vendor put in them. This is in the model itself and independant of any textures used. They do require you to bump up the model resolution to actually be visible because they need the mesh to be dense to add the details.  In most of the HD morphs I've seen this is most visible in the face, especially the lips. But it can be much more than that, Zev0's HD aging morphs will turn your debutante into a wrinkled hag with a push of a slider.
    On the other hand NGS 2 does not work on the mesh at all. It works on the materials applied to the mesh. Basically it sets those materials up such that the IRAY render engine can figure out how the light will be reflected/absorbed, what color it ought to be, how it ought to show things in the render. It is not dependant on the mesh below as long as it's designed for that mesh. So you can make the mesh higher resolution and the materials aren't affected. You can add HD morphs and the materials aren't affected. If you add NGS2, the mesh is not affected either but the material settings are modified heavily.
    If you use NGS, in my opinion your skin materials will look better in most cases. If you use HD morphs, you should get more phsyical details in the model.  You can use one or the other or both to suit your needs and desires.  Hope all that makes sense.
  • CybersoxCybersox Posts: 9,266
    Coincidentally, I just re-did an image made with Zev's Aging morphs.  The original version is here and this an equivalent sized copy of the new version with NGS 2 added.  There's also a  larger version on my DevArt page.
    1385 x 1800 - 2M
    Post edited by Cybersox on
    Why did it become reddish? with the NGS 2? and it made some of the wrinkles less defined?
  • This is one of the best IRAY products I have purchased. Its very easy to use, makes the skin tones from Genesis, G2 and G3 look even better, more photo-real, with no problems, just one click and then if it looks a bit dark or light, you have a few options to tweak it. So far, I have been very happy with every one of my figures, the skins just look great. I use the High Level Pores, seems to add a bit more crispness and sheen.
    Great product! If you are looking to get realistic skin tones from any genesis character, this is the best one out there and very easy to use! Thanks for making such a well thoughtout script.
  • Oso3DOso3D Posts: 15,085
    Cybersox, that's AMAZING. I LOVE HER.
    It's partially due to the NGS 2, partially from slightly different post-work but mainly because the original was lit entirely with spots to make the wrinkles stand out more, whereas the newer version is lit with mesh lights and only has a single side spot to kick up the specular on the skin.  I learned a lot about Iray lighting during that contest...
  • jcbunnjcbunn Posts: 271
    Darius 7
    Left, used Anagenessis 2 Dark Skin Genesis 3 script in the Dark Skins Folder
    Center, Anagenessis 2 Skin Genesis 3 script in the default Folder
    Right, Normal Iray
    Darius 7 Gen parts look perfect, NGS2 also looks great in Daz3D Beta version.
    981 x 540 - 2M
    Post edited by Chohole on
    Thanks.  She's a composite of a lot of various women I've seen working in restaurants over the years and I rather adore her myself. :)
  • nicsttnicstt Posts: 11,715
    You could delete the skin textures, but leave a Placeholder :)
    Select the the texture with Ctrl A and then delete, and you're left with it 'as is'.
    1049 x 838 - 84K
  • Loving N.G.S. Anagenessis II - Revolution, it has become a necessity that I use on everything.
    Has anyone had good results with DAZ Big Cat 2?  I still can't seem to get good results (I never got good result with reular Iray shaders either).  Any tips?
    960 x 1080 - 112K
  • xyer0xyer0 Posts: 6,326
    I have not kept up with this thread since page 12 or so. Can anyone save me thirteen pages of reading and tell me what parameter I change to lower the Pores level even more? I have not had much success with lowering Bump or Topcoat Bump.
  • Hello. I really want to try this. I use Reality and Lux Renderer. Will this work with them?
    Thank you
  • mark128mark128 Posts: 1,029
    I've been trying to get the V7 Merchant Resouce Pale Sking maps to work with the NGS Anagenessis 2 Iray shaders. In this image I used:
    Victoria 7
    Victoria 7 HD Add-On
    Victoria 7 Merchant Resource - Pale Skin
    N.G.S. Anagenessis 2 - Revolution
    Macro Eyes for Iray Bundle
    Iray Lipgloss and Lipcolors for Genesis 3 Female(s) by outoftouch at Rendo
    Seema Hair for Genesis 3 Female(s)
    Monokini for Genesis 3 Female(s)
    InaneGlory's Photo Studio - Point and Shoot Iray
    The NGS Anagenessis with the Bright preset script and with the blues turned down in the glossy color a bit.  Maybe need to adjust a bit more.
    Post edited by mark128 on
  • BeeMKayBeeMKay Posts: 7,019
    Thank you
    No, it is for Iray, not Lux Render. I don't think this will work in Lux.
  • HeraHera Posts: 1,958
    I've got this one but finding it hard to use. I tried to apply it upon a G2F SSS-texture to be able to use it in Iray.
    However how do I get skin to look realistic? It's less victimized by the hard iray light business that  is true, but all I end up is something which look like in the days before SSS. A kind of paperish look. I've been experimenting with most of the settings, but the only thing happening is that the colours keep changing just the tiniest bits. Not possible to add smooth shine, as far as I can tell.
    I'm hoping to aquire some soft kind of glossines or alike to that 3Dlite/SSS-effect when the skin looks like it's softly lit/reflected from inside. Is that even possible in Iray?
    And what kind of light will I need to use? Can I use this together with the 'classic' spot light and distant lights?
    And from the tutorial - what is a LIE Image?
    What does the Anagenessis 2 !Glossiness Caution do?
    "What does the Anagenessis 2 !Glossiness Caution do?"
    Pretty much exactly what it says. A notice not to have any surface selected when you apply that type of preset.
  • XoechZXoechZ Posts: 1,102
    Sorry if this has been asked before, but this thread is already very long. What I want to know is:
    How does this product affect render times? Do these skins usually render faster or slower compared to the standard skins?
    What about ressources? Do these skins use more or less VRAM than the standard skins?
    Thank you!
  • FistyFisty Posts: 3,416
    I haven't noticed any difference in render time vs a setup that was already iray uber.  It uses less vram because it only uses the 4 diffuse textures for the skin and not the extra 15-20 support maps
    Cool!!
    Thank you very much!
    Fisty: it's almost embarrassing how it does so much more with way fewer maps
