Enlarging Renders
Render size,how do I enlarge my renders? I'm not computer savy at all, so tech talk just leaves me puzzled. I'm 77 years old and was born way before the computer world came along, but I use Daz as a hobby, and would like to do full length portraits. Can someone help me please.
The General group in the Render Settings pane has the size controls - set the Dimension Preset to Custom (should be optional, but some people have had trouble changing size if the wrong option is set here), set Constrain Proportions to Off, and then enter the width and height (in pixels) in their boxes - the Aspect ration will update, you can ignore that (or if you want to work to a set proportion, enter the values in the Aspect Ratio boxes, leave Constrain Proportion On and just enter the width or the height to have the other value update).
One of the problems with most of the presets is that they don't have flipped width/height settings. Most of them are 'wider than tall.' So a 5:4 (1000:800) doesn't have corresponding 4:5 preset, so it needs to be made as a Custom setting.
