Fitting A3 outfit to A4?
http://www.daz3d.com/sugar-for-a3-outfit-bundle
How can I use this? I want to take this one, but I don't have A3... so, is it possible to right click and fit to A4 or V4?
  • SixDsSixDs Posts: 2,384
    edited December 2016
    Well, lets see. Be back in a jiff.
    OK. "Fit To" ? No go. I disabled "Fit To" so I could use the adjustment dials, and found that I didn't really need to use any morph dials, but by scaling it up a bit (both corset and panties) and adjusting the transformation, it fit pretty well. However, I didn't try any character morphs or poses to see how it behaved itself. I could have achieved a better fit on the waist using the built-in waist adjustments.
    BTW, you do realize that there is a V4 version, right? http://www.daz3d.com/sugar-for-v4-bundle
    1000 x 1000 - 199K
    Post edited by SixDs on
  • CherubitCherubit Posts: 995
    thank you! that girl you fitted to is a4?
    yes haha, i found out way later after i posted here :) i decided to add the v4 one to my wishlist instead of getting this a3 as freebie... i'm a total noob with generation 3 below...
    "that girl you fitted to is a4?"
    Yep. That's the "base" A4 as loaded. Note: although I was able to get a pretty good fit without too much trouble in the "T" pose, as soon as I applied significant morphs or changed the pose, I needed to adjust the items to fit once again. To make it fully functional would need a great deal more time and effort (transferring morphs from V4, etc.), or the use of one of the various transfer utilities for moving clothing from one figure to another. Of course, the V4 version should work just fine out of the box.
