Carrara installation
ArhainArt
Just purchased Carrara 8.5 Pro and saw both versions in downloads as well as serial numbers. Do I need to install 8.5 first and then the pro, or can I just install pro version?
It's the serial number that turns it into Pro. The non pro download is actually 32bit version and the One showing as Pro is the 64bit version
Thank you! Just wanted to be sure.
