Is there way to stop auto-up date prodcut meta data for each prodcut?
kitakoredaz
no!
Post edited by kitakoredaz on
kitakoredaz
no!
What I suggested in 2012 / 2013 was:
- to make a clear difference between official DAZ3D metadata products .dsx files
and
- .dsx files created by the user so called "User created metadata product files"
-> In theory this would mean the official .dsx and exported user created .dsx are saved in two different locations.
In the CMS database itself there also needs to be a clear distinction between official and user created metadata.
-> For each product the customer could set options
A) official DAZ3D metadata is downloaded from the server -> toggle yes or no
or
B) "User created metadata product files" are never overwritten and always applied and displayed inplace of the official metadata
With DIM and Valentina it seemed to much work to implement such a system because only a few peopled seemed interested in creating their own metadata.
Nevertheless I wonder if Connect and PostgreSQL now would be better suited to find a solution?
Which version of DS? This is something that has received a fair bit of attention, user categories separated from thge main categories should be more secure (you can opt to hide the original categorisation but I think you need the ebta for that to be available and to stick following an update).
may better to stop daz connect. it simply confuse many new user.
