How to make IRay use GPU rather than CPU?
I'm doing a test render of genesis. I have a GTX 1070 selected with optix enabled but it still only uses the CPU. If I select just the GPU and no CPU then nothing gets rendered. Here's the log file:
2016-29-07 16:29:55.720 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating geometry.
2016-29-07 16:29:55.720 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Using OptiX Prime ray tracing.
2016-29-07 16:29:55.767 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Geometry import (1 object with 151k triangles, 1 instance yielding 151k triangles) took 0.034193
2016-29-07 16:29:55.767 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating materials.
2016-29-07 16:29:55.773 Iray INFO - module:category(MATCNV:RENDER):   1.0   MATCNV rend info : found 137 textures, 0 lambdas (0 unique)
2016-29-07 16:29:55.774 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating environment.
2016-29-07 16:29:55.780 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating lights.
2016-29-07 16:29:55.780 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating object flags.
2016-29-07 16:29:55.780 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating caustic portals.
2016-29-07 16:29:55.780 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Updating decals.
2016-29-07 16:29:55.782 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Using batch scheduling, architectural sampler disabled, caustic sampler disabled
2016-29-07 16:29:55.782 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Initializing local rendering.
2016-29-07 16:29:55.783 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : CPU: using 4 cores for rendering
2016-29-07 16:29:55.783 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Rendering with 1 device(s):
2016-29-07 16:29:55.783 Iray INFO - module:category(IRAY:RENDER):   1.0   IRAY   rend info : Rendering...
2016-29-07 16:29:56.884 Iray INFO - module:category(IRAY:RENDER):   1.3   IRAY   rend info : Initializing light hierarchy.
2016-29-07 16:29:57.050 Iray INFO - module:category(IRAY:RENDER):   1.2   IRAY   rend info : CPU: Scene processed in 1.267s
2016-29-07 16:29:57.051 Iray INFO - module:category(IRAY:RENDER):   1.2   IRAY   rend info : CPU: Allocated 7 MB for frame buffer
I've attached a screenshot of my settings, how do I get it to use the GPU? The GPU has plenty of free memory so that should not be the issue.
I read this thread but did not find a solution: http://www.daz3d.com/forums/discussion/74758/daz-iray-not-using-gpu-to-render
Thanks for your help
  • fastbike1fastbike1 Posts: 4,081
    The current release version (4.9.2.70) doesn't support Pascal GPU's. The current Beta version (4.9.3.128) will, but it is still Beta software.
    Same answer as in the thread you referenced.
