There is a add on for G3F?
I'm looking for add more details to the G3F model. There is a add on for G3F?
Thanks!
  • nonesuch00nonesuch00 Posts: 18,765
    These are probably the top three that you want:
    a. Genesis 3 Female Head Morphs
    b. Genesis 3 Female Body Morphs
    c. Genesis 3 Female Expressions
    Explain...
    There's lots of ways to add to G3F...but what exactly do you mean by details?
  • I'm sorry. I mean a add on like this http://www.daz3d.com/victoria-7-hd-add-on (image attached)
    1000 x 1300 - 148K
  • FSMCDesignsFSMCDesigns Posts: 12,846
    edited December 2016
    Do you mean an HD morph for the genesis 3 female base figure? That is what character addons are for, to add detail. Also keep in mind that cranking up the sudivision makes any details come out more.
    Post edited by FSMCDesigns on
  • Similar topics regarding creation of HD morphs for the Genesis3 series have been discussed at length in past. Summarily, you cannot create HD morphs unless your are a Daz PA as only they have access to the required tools. But if you want, you can use the GoZ bridge to export the details added by existing HD morphs outside the studio into your GoZ supported application. Another option would be to export as OBJ or FBX, but then you would have to manually rig the characters.
  • Do you mean an HD morph for the genesis 3 female base figure? That is what character addons are for, to add detail. Also keep in mind that cranking up the sudivision makes any details come out more.
    Hi FSMC! Yes that is what I mean laugh
