JavaScript seems to be disabled in your browser. You must have JavaScript enabled in your browser to utilize the functionality of this website.
Hi, I have a problem. When trying to set one object to another, and the scene looks good, so when rendering objects collide.
On the scene it is well, and when rendering objects collide se each other
Normally, that happens when an object has additional depth by HD, or other depth-controlling maps. This sometimes also causes poke-through in clothing.
What are you trying to collide?
G2F and bed from hotel room but it started when loaded on the scene G2M and loaded on him Iray optimize genesis 2 male MAT
Well, the easiest solution is to move G3M away from the hotel bed a bit. using the dials in the parameter tab.
