Nigel & M4 textures not loading properly on Genesis
mtnmenmtnmen Posts: 444
I am just now dipping my toes into the Genesis pool... I have a lot of M4 clothes etc. so I made my Genesis 100% male 100% M4... not to mention some modified textures adding body hair... I thought that a full M4 would accept the m4 textures... but there are issues of seams showing, as well as the face texture being applied too low on the the actual face... So I bought Nigel for M4 and Genesis thinking that the Genesis form needs a Genesis specific texture... I applied it and encountered the same issues. The attached images show what happened .to poor Nigel. Any ideas as to what I did wrong or what I need to know would be greatly appreciated.
Like I said this is my first fooling around with Genesis... so I need a lot of help.
Steve
  • SzarkSzark Posts: 10,634
    Select the figure, in the Surfaces Pane look for UvMapping and change the UVmapping to M4 and lock the padlock so it doesn't slip off the setting.
  • mtnmenmtnmen Posts: 444
    Thank you so much... Wow how easy is that? I just love single clicks that make such a difference...
    I really appreciate it...
    Steve
  • wancowwancow Posts: 2,708
    do watch that... different presets will set different UVsets... sometimes you have to change it back. It's always the first thing I check :)
    my pleasure Steve. Yeah most things are easy to fix when you know how. :)
