[solved] Shaders option disappeared for some items
Solved
So my shaders option disappeared for some items, specially wardrobe and hairs... (in characters it works)
I select the item in Surfaces > Edit, and then go to the Presets tab, and all I see is the Materials option.
It was working well yesterday :/
Any clues to what I can do to fix it? Maybe reinstall DS?
EDIT: I noticed it happens when the items are fitted to a character, I can't apply shaders anymore.
Post edited by Cherubit on
Do you have the base item selected? If an item is fitted to another clicking on it in the viewport will select the corresponding bone on the base figure, unless the bone is unique tp the fitted item. Right-click will give you access to the topmost fitted item, or use the Scene pane to select.
haha it was fitted to a figure, then i selected a figure in the scene panel, and selected the fitted object surface or surfaces, I gues this is why it wasn't working :P
Thank you! :D I had to select the item in the scene too haha...
