Content not showing up in Daz3d ...
I have a new computer i7 Intel and a Nvidia 1070 card.
I have a primary SSD (C) where I installed Daz3d but it is only 120gigs. So i installed all my content to reg Sata hard drive...(E) which is 2 terabytes.
So I startup the Daz3d program no problems, but am unable to load content...see attached file.
Used the DIM to install all content and verified all my inventory went to the E drive.
Hope that is enough info...if not I will be happy to elaborate.
Any ideas would be appreciated,
PS...added the DIM path settings also...if that helps.
Kent
Post edited by kentphoto on
I have Daz3d on the primary C drive 120gigs, which is a SSD And I put my Daz3d content on the E drive which is 2 Terrabyte drive.
Kent
Did you add the path to your content inside of DS itself (not DIM)?
I would not put program Files in the path - Windows may decide to protect the location. However, the main issue may be telling DS where you content is - have you added the folder you are installing to as a DAZ Studio Format and a Poser Fomrat content directory in Daz Studio? The folder should be listed under those heading in the Content Library pane, if it isn't you can add it be right-clicking on the heading and selecting the Add Base Directory/Add Runtime Directory command.
Merged threads
Sorry, I don't understand what you are saying. Can you tell me in a Step 1: do this Step 2: do this.... format.
Sorry to be so dense when it comes to understanding Daz3d and the root folder system.
Here is a link to the documentation on the Content Directory Manager.
Thanks Barbult...this should help! :)
