Iray shaders image folder
I'm making a freebie and I don't know what folder to put my images for the shader... some help please? :)
thank you! <3
(i've googled and only found a couple posts about 3delight, and i wasnt sure so one said it should go in runtime folder?!)
Post edited by Cherubit on
If you were a vender you'd go ahead and set up your shader freebies like the vendors do. If you want to do it that way you'll need to wait for a PA to come by and advise you.
For freebies like you are doing but as a artist not a vender the regular was is to put / save them here:
<System Path>\<DAZ 3D Library Path>\Studio\Library\Presets\Shaders\<Your Avator Name>\<SDL><3DL Shader Set Name a, b, c..z>
<System Path>\<DAZ 3D Library Path>\Studio\Library\Presets\Shaders\<Your Avator Name>\<MDL>< iRay Shader Set Name a, b, c..z>
Those are for preset files and the icons for those preset files.
If you have actual new shader definition language files you have created, wait for a shader vendor to help you with where and how to put those in the DAZ Studio structure.
As in texture files for shader presets?
If, so, make a folder in your name, with a sub-folder of the product you are creating in Runtime/Textures.
Put the textures in the /Runtime/Libraries/Whatever folder in one of your content directories before applying them to the model, or reapply the textures from their new location if they have already been applied.
