Garibaldi Express problem with Available Surfaces Problem
5200north
in The Commons
I fired up Garibaldi Express for the first time but i got stuck on the setup part. When i loaded G3M then "created a Garibaldi Hair"' then went to "edit garibaldi hair",then when i go to selectthe areas to paint they do not list what is on the tutorial, nor if add a differrent figure, like Hivewires new cat, it is setup correnctly so i can paint specific areas.
if you look at the attached photos i think it will expain my proplem better than i
http://www.daz3d.com/forums/discussion/comment/845656/#Comment_845656
See here for premade G3M/F maps
http://www.daz3d.com/forums/discussion/comment/865479/#Comment_865479
The other option is to use a skull cap fitted to the figure, rather than the figure itself. This has another benefit too, you can then autofit the skull cap to different figures as well and use your hairs cross generation
This one by mustakettu for insatance was designed for LAMH, but works equally well for garibaldi IMO
