G3F Eyes (P3D Models)
Octavia Moon
I have this problem with a couple of my character models (only, so far, found on P3D models).
Usually, if I want a model to look at something I move her eyes left/right (SIDE) or up/down - sometimes I use 'point at'.
Unfortunately, using these Controls for some models results in them moving completely randomly.
I've done nothing to these models to change settings or anything and I have no idea if this is something that I can fix or it's a problem with the 'rigging' (I don't know what I'm talking about obviously :)
Can anyone offer suggestions or a way to contact the artist?
Thank you
Files attached - first is 100% UP/DOWN second is 100% SIDE/SIDE
Post edited by Octavia Moon on
Put in support tickets. https://helpdaz.zendesk.com/hc/en-us/requests/new
It can be a common problem with custom sculpted morphs, if care is not taken when finishing the final steps, before saving the morph. And no, it's not really fixable,
Figure...the base model. (Genesis 3, Genesis 2, Genesis)
Character...a morph package for the base figure.
Ok thanks - I'll sort through which characters are affected and then submit a ticket with a lst...thanks for letting me know :)
I think, it is about " default eye rigs (and some eyelids rigs) orientation" of genesis3 female.
Is there any practical reason to change "Z rotate orientation" 180 for L eye, and -180 for R eye.
please teach me, why DAZ need to rig so , if clever person know . if it was not simple mistake, and there was clear intention. and the merit about it.
Once it rigs so, about base figure,, ,, all new actor need to keep same rig orietantion arrangements, to work with same eye pose controller correctly.
lets check genesis2female rigs. there is no X orientation about eye rigs.
then,, (eye Up-down ) (UP = -X rotation, Down = + X rotation., Eular ZXY cordinate )
actually G2F eye parameter work so. (X rotation UP = -x rotate, Down = x rotate) , and when move controlelr to Down side , eye down = x rotate.
when move controller to Up side , eye UP = (X -rotate) as same as parameter "label = Up - Down"
but about genesis3 ,,, DAZ apply orientation 180 and -180 for both eyes. Z orientation.
then now,,, genesis3 eye UP-down (UP = + rotation, Down = - Xrotation,, with Eular ZXY (orientation 180 )
though it may work,, When set rigs for eye, But we may not try to orientate X (twist) 180 for eye and eye around rigs..
I checked all facial rigs,, but why some rig only apply those Z (twist) orientaiton, but some rigs not ? about almost same direction rigs?
Is there clear,, and articulate rule,, when DAZ apply Z orientation for rigs? (about almost same direction) ?
At same time, I think DAZ never plan to modify G3F base figure rigs anymore .. because too many products for genesis3female have been released already. if change it,,there are many product which need to re-adjust,, I think.
