Body Paint??
Been trying to figure out a way to create a body paint look for a render. Not trying to create something all new. Just want to make an outfit look like it's painted on.
Not having much luck. Seems the only way to do it would be to edit the base skin texture image. Way more difficult that I want to get into.
Any suggestions?
What application are you using? If DAZ Studio, research the Layered Image Editor.
Skin-tight clothing could of course be used. There is also something called "second skin" clothing, which is basically just a body material that has clothing painted on, that you can buy. Not sure if anybody does that for the newer figures.
FYI - I found the only workable option so far to be geometry shells. They do the job nicely and it's easy to add a texture to them that makes them look like amateurish body paint.
