Morphs problems with genesis base figure
Hi, guys.
I have a problem that take me days for resolve and I to start very tired and a bit disperate.
I have been worked in Genesis figure in poser 2014, I make dozen of special character using a genesis figure like base, but personalizing those with Morphs Inj. that take me LOTS OF HOURS. (not just bodies but faces etc.)
Tryng to make order in my computer I make a entire new library for poser (with the same material, morphs and figures of the oldone, but in a more clear order, instal poser 11 and after that, when I try to open my .pz3 file with the characters with all the morphs...they have dessapear!!! I mean, seems like they are there, but just in a form of a thin black line. I send an image for better explanation. Not sure, maybe is the new Dson version that have also instaled?
Seems that the problem is in Python (like you can see in the python window). At the side you can see all dthe dials and the configuration seems ok, but i cannot visualiza the morphs.
I comeback to the old poser2014 with the old library but the problem now is the same there...
I have try to reinstalling again the poser but that dont work...
Those morphs takeme days of work and I need them. anyone have an idea of what is the problem? any help is REALLY welcome!!
I have had to delete the screenshot as it showed the bare, albeit anatomical elementless, groin.
Did you install the DSON Importer plug-in, and did you apply the Poser service packs?
So sorry, Richard, for the image. I have upload a new one with the correction.
The problem persist, but is weird. When I restart the computer and open Poser 2014 I can work well with the files for a while, but at some point, after 10 minutes of work when try to open another figure, start the same problem again. So, I guess is something there that are in conlfict with the Dson importer. I have the last Dson version. For the service pack, you refer to Poser 2014 or Poser pro 11?
The message that appear sometimes when I start poser (both version) is "An errror occurred importing addon PythonShell :
ERROR: DLL load failed: The specified module could not be found."
Maybe is time to formatted the whole computer and reinstall all from scratch.
Also, is any way to export my character morphing in a .Cr2 file? I mean, make my genesis base character with all the morphs and changes an original figure in order to save this conflict or failure with Python?
Thank you.
Just crop to show the Python console, and if you want to show the figure crop at waist level. Adding an obscuring element after the fact doesn't work - see http://www.daz3d.com/forums/discussion/3279/acceptable-ways-of-handling-nudity#latest
None of the Python errors in that screenshot are from DIM itself. Theer may be earlier calls that have scrolled out of sight, but if not it looks like a fundamental issue with Poser rather than a specific DSON issue.
The CR2 should be loadign the morphs - again, this looks like a problem running Python scripts in general or some kind of conflict (possibly with the DSON Importer but if so the evidence is not visible). Do you have any other plug-ins, such as Reality, or permanent Python scripts?
Thanks, Richard. I still have this problem after I working for a while in the software. Since I have reinstall lot of old stuff, maybe , like you say, have create a conflict with Dson. Unfortunatelly my knowledge of this things (DIM, permanent Phyton scripts etc) are very, very poor, since I use this software just for artistic reference and not for 3d properly. is fdifficult for me, after installing at the same time lots of props and scenes and characters and morhps and stuff in the Poser, known what exactly have made the conflict.
In the week I try to formatting my computer (Something I had to do a long time ago , since my computer for 4 years have worked hard without formatting-and exist the slighty posibility that other software produce a conflict with Poser) and reinstall Poser again, and try to see what happen. In case that the probelm appear again (or is resolved) I comeback here for fourther advice.
Meantime, than you very much for your time, help and advice.
It shouldn't be the content that is causing the issue - at least as long as you don't place any content in the application folder, just leave that for the core files and add-ons like the DSON Importer that need to go there.
