Remove Triangle,Using Decimator
Hello everyone, I have an issue with decimator when put on the cloth to genesis 3.Decimator Work nice without cloth but when I put on a cloth on it and click on prepare for decimate it begins to look like the attached picture.Anyone Know how to fix this issue?I use 4.6 and 4.9 its the same on both.
Not sure about charater texture, but with the coat maybe go into shaders and replace textures with shaders.
Hi, Thanks for your advice , it worked with coat and stoped the bug but it still remove character faces.
Sometimes decimate an item when it isn't parented, works better for me.
I then save as a subset.
Thanks for the advise , It didnt work in this matter.BTW I found out that the problem will happen when I use this shoes or other shoes with heel and it is ok with shoes with no heel.
