How can I stress test an installed second video card?
nDelphi
in The Commons
I got my GTX 1080 and I would like to stress test it as I don't have use of it with DAZ Studio as I only have the General Release. The problem is that it is installed as the second video card. I tried FurMark and Kombustor and I didn't see any way to select individual cards or even get them to stress test the second video card.
I'm unfamiliar with the tools you mentioned, but if they work can you just temporarily remove the other graphics card so this is the only one, forcing it to get used in the test?
In GPU-Z on the graphic card tab you can click on the question mark (next to bus interface) to do a mini stress test but perhaps you are looking for a better test than that
The last thing I want to do is remove cards, let's just say that I had to rearrange stuff to get that GTX 1080 in the case.
I tried GPU-Z but no matter what card I have selected the test is done on the primary card, my GTX 960. It is the same behavior I am seeing with the other stress test tools. The card is visible to the OS, DAZ Studio, etc. Even the stress test applications can see it and report on it. I am baffled.
Why do you want to?
Stress-testing is done by rendering, it is presumably what you're using it for. You get realistic data then from actually useage.
GPU-z gives good info, whilst you're rendering.
But, if you want temperatures, I'd use something like Hardware Monitor, http://www.cpuid.com/downloads/hwmonitor/hwmonitor_1.30.exe
There are benefits to stress testing, but there are also risks; I tend to avoid for my own use.
Because I am not using it at the moment and wanted to make sure there are no issues with heat. I am not going to install the beta of DAZ Studio, so it will be some time before it gets used.
Fair enough. :)
But you're going to have to install something, and testing it with HWMonitor and Daz Beta gives you real world data; it will be what you're using it for so relevant to you, not a collection of generic tests, and you can uninstall beta after you're done.
Otherwise, you already have some ideas.
Maybe you can get some idea about how your system performs when you run the OctaneBench while at the same time having a look at the temperature in GPU-Z?
It may not run that long. But at least you get a temperature estimate and system check with all available GPU.
OctaneBench is the official software from Otoy to test how all your GPU perform.
Officially the OctaneBench application was not yet updated to test Pascal cards.
Unofficially some savy forum users moved some files around and now you can also test Pascal cards...
Quick guide:
- First read how you would install and run the OctaneBench test normaly here:
https://render.otoy.com/octanebench/
- Then perform the same steps with the unofficial version:
https://render.otoy.com/forum/viewtopic.php?f=9&t=56108
- Download .rar file attached in the first post by unica of the linked thread
- extract .rar file
- Double-click the script "_run_benchmark.bat" in the Windows Explorer.
No need to start the included OctaneRender test version...
- Select the installed GPU you want to test
-> Now a series of test scenes will render
After the test scenes have finished rendering you get your score.
Alternatively:
Wait a few days, weeks or months until the official update for OctaneBench is released.
Can you not simply disable your primary card temporarily in Control Panel so that the system defaults to the new card? That is easier and quicker than physically removing anything, and when the testing is done you can re-enable the primary card.
Thanks all. I will look into these suggestions.
No need to actually disable 960, just set 1080 to primary display temporary and plug monitor into it. As long as you don't hit the 8GB limit (minus running Windows desktop) when rendering you can even leave it primary and it will add the 960 automatically for rendering as long as the scene file fits into the 4GB limit too - vice versa it probably hits the 4GB limit far sooner if that card runs Windows desktop too, not using the additional cuda cores from 960 anymore then. If your scenes come closer to the 8GB limit often it would be recommended to keep the 1080 free from running Windows desktop, but I guess you more often reach the 4GB limit than the 8GB (once Pascal support is added to release version, and until then you free some extra memory from 960 for rendering when using 1080 for desktop) ..
