Bizarre problems with DIM after moving Daz Library
LlynaraLlynara Posts: 4,772
I'm having strange problems with DIM after I moved "My Daz Library" to an external hard drive. I changed the paths, following directions here in the forums both in DAZ3d software and the DIM.
The first time I logged into DIM, it showed no packages to download. It showed the installed packages just fine. I have over a thousand items I haven't downloaded, so I'm not sure why it would be showing 0. All the authentication looks correct. I closed the program and relaunched it, hoping to get a screenshot to post here. Now I can't log into DIM at all. It's telling me it can't authenticate the account, but clearly I can log into DAZ since I'm posting here and am logged into the store. I've checked my credentials and they look fine.
Has anyone else had this issue after moving files? What's the fix?
Post edited by Llynara on
  • LlynaraLlynara Posts: 4,772
    edited November 2016
    Nevermind, looks like others are having the same problem on another thread. The library move doesn't seem to be connected to the issues. The timing made it look like it was.
  • Daz has actually problems to login in the last 24 hours. Maybe it's simply this.
