Where did Headshop go?
2»
  • tring01 said:
    There's something I'm still not quite getting here.
    In Headshop the shaping was imported as a custom morph.  Thus one could just apply any compatible Daz texture.
    Is that NOT possible with this new product?  It seems you implied not, but I'd like a clear statement.
    So, can I use a Daz texture with this new product or not?  Your answer will determine if I buy.
    No, you can still use DAZ textures and in most cases you will absolutely need to use DAZ textures because it's rare that a picture used to create one of these morphs is good enough and in high enough resolution to create a texture from. It will have things like shadows alway in the same place of the face no matter how your lighting is set up and so on. So yes, you can and probably should use DAZ textures.
    When can I buy this product?
  • nonesuch00nonesuch00 Posts: 18,795
    The author said it will be in the DAZ Store in December.
    This is a link to the author's DAZ Store so check sometimes:
    http://www.daz3d.com/abalone-llc
    I am not affiliated with the author.
  • Ati said:
    Will it work in version 4.8?
    Yes, all Studios 4.6 and up
  • I am happy that people pressured us to double the render from 1024x1024 to 2048x2048. It really shows:-)
    878 x 731 - 216K
  • Another one....2048x2048 texture
    878 x 731 - 252K
  • FSMCDesignsFSMCDesigns Posts: 12,848
    Nice, imagine how good it would look at 4096 x 4096, like the standard DAZ textures, LOL.
  • few questions is this version going to installed via dim and or connect or download from our bought product pages, if we have both the full version of daz 4.9 as well as the beta version out now do we have to do seperate installs for both programs and also do we have to manually create any folders or copy paste any files in specific areas like we did with headshop 9 - didn't get 10 so don't know how that went
    OneClick is downloadable and comes with its own installer. There is no need to manually install anything, the installer installs everything as needed (separate installers for 32-bit and 64-bit). Caution: in all likelyhood OneClick will not work with beta versions of Studio, as betas have different naming conventions.
    well that still works then all gotta do is create the head texture in the last full version and if using the daz beta all we gotta do is import the saved created texture via surfaces tab often done that created the face texture then in paintshop done any touchups wanted then reimported via surfaces
  • tring01tring01 Posts: 305
    Bought it!
