Changing an object's orbit point?
SnowSultanSnowSultan Posts: 3,797
Maybe I'm missing something obvious, but I cannot figure out how to change the orbit point of an object or figure. I have a few things that have rotation and translation points set to the world center, and even when they're parented to another item or if I change the coordinates in the Tool Settings panel, the main point doesn't change.
Any help would be appreciated!
  • wancowwancow Posts: 2,708
    I've asked this question three times on this forum, never got an answer :(
    You can change the pivot point using the Joint Editor in Daz. It's under the Tools menu.
  • ReDaveReDave Posts: 815
    Szark has a nice screenshot here: http://www.daz3d.com/forums/discussion/4721/
    There it is! Wow.. finally! Then just go back to the universal tool when it's set, and all done! Sheesh... that was easy!
    Sometimes the hardest problems have the simplest solutions.
  • SnowSultanSnowSultan Posts: 3,797
    edited December 2012
    Thank you for that link, it solved the problem. A little tricky to get it accurate, but at least there is a way. :) Much appreciated.
    Post edited by SnowSultan on
