Personalize your Daz4 Studio?
What is this supposed to do exactly?  And how do I turn it off if I choose not to do it?
  • FSMCDesignsFSMCDesigns Posts: 12,851
    Curious, where do you see this??
  • IvyIvy Posts: 7,165
    Hi Ice dragon  Richard  had showed me where you can customize your  studio program colors & layout  or how you arrage tabs . you find it  on the top  > windows . Style> customize style.. I hope that helps
    edited November 2016
    Its a pop up window I get whenever first open Studio.
    562 x 585 - 88K
    Oh . I see . I maybe wrong but it kind of looks like a set up option for when installing daz studio for personlized authership information. like the same option . under the preffence tab under edit >general .  when do you get this pop up? not sure if thats the same thing but it looks like it might be a set up for the authership
    942 x 785 - 81K
    Post edited by Ivy on
    If you make any content for DS it will save with the info you put in there as the author of the content.
    Laurie
  • srieschsriesch Posts: 4,243
    If you don't want to see it again, presumably you can check the "Do not show me this again" option in the bottom left (well, obviously you will see it again on your next fresh install of course, but that shouldn't be very often.)
    It pos up every time I open studio.  Clicking the don't show this again button doesn't work....
  • It pos up every time I open studio.  Clicking the don't show this again button doesn't work....
    Try entering a name you want to use for  for files you create such as scene file (You don't need to enter anything in the URL box), check the "do not show this again' box, then click OK button.; and see if this takes care of the problem.
  • MattymanxMattymanx Posts: 7,000
    Basically what it does for the end user is it tags all your saved scenes as yours and lets you overwrite a saved file you are working on instead of popping up the save as window
    I don't get that either, but then again I don't use smart content, DIM or connect, so it appears there might have been an update for this to happen.
    Will give that a try Charlie Judge thank you.
    Never would have thought of that Mattymanx thank you.
    Ya I use DIM.
  • fastbike1fastbike1 Posts: 4,081
    I use DIM as well, but the "don't show this again" checkbox works for me.
