camera headlamp default setting
One of the most annoying things about DAZ studio is that the camera have the headlamp defaulting to on (well, specifically to auto) which makes all your renders look horrible and messes up your other lights
I keep forgetting to go in and switch it off when I create a camera. Is there some way to have it default to off?
Post edited by Sertorial on
If you set it to Never in Render Settings the Auo on the camera should respect that (and does for me).
Aha! Brilliant. Thanks
Depending on your settings in Preferences, loading scenes saved BEFORE you made the change, may reset it. If you have the render settings options "Ignore when opening a scene file" unchecked and the Record when saving checked the render settings will be saved and then every time you open a scene, they will reset to what they were for that scene.
