Ankle bracelets?
JQPJQP Posts: 526
edited November 2016 in The Commons
Talking modern jewelry. Anklets, whatever you want to call them. Simple chain around the ankle, maybe with some charms or the like for variety. For G3F, though I get pretty good results converting from V3/V4/G1/G2F. I've dug through my own library with little success. Other type of ankle accessories are welcome, as long as they're in a relatively modern style.
Edit: wrist stuff welcome too, actually. I've got several, but more can't hurt.
Post edited by JQP on
    Greetings,
    This has been a quest of mine for a bit; there's not much out there for the ankle.  I don't have a ready list, but here's a few references:
    There's Jewelry Basics for G3F which has bracelets that could be re-used.
    The Fantasy Collar set has a lot of textures (all the old textures for V4/Genesis work) which reduce it to a nice, small anklet.
    There's a character on 'rosity who evidently includes an anklet, but I don't have the character.
    The Amythest outfit includes a pretty nice one that's probably reasonably adaptable.
    Beyond that...I haven't seen much, honestly.  It's annoying because bracelets (of which there are a lot) don't lay quite the same as anklets, so I always have to do a lot of fiddly tweaks to make it look reasonably right.
    --  Morgan
    I've been thinking of making some actually. Just need RL to quit intervening so I can get it done ;). I only do freebies, mind you.
    Laurie
  • srieschsriesch Posts: 4,243
    http://www.daz3d.com/spring-fling for V3 has an ankle chain.
  • JQPJQP Posts: 526
    Wow, we need to close this anklet gap! :)
    Morgan, TYVM. And thanks for the info about the Fantasy Collar set. I could never really figure out what the heck it was good for. The textures you refer to, are they included, or are they in other products or freebies or something?
    Laurie, free is good! I look forward to it :) (Going to go look for your website now)
    SRiesch, thank you.
  • I think an anklet set with charms from Fisty & Darc would be great.
  • FSMCDesignsFSMCDesigns Posts: 12,846
    I am all for some anklets, as long as they have some morphs to simulate movement. I tend to scale down necklaces and use them when the need arises
  • JQPJQP Posts: 526
    Loissandra Outfit for G2F has a cute anklet.
  • thrain9thrain9 Posts: 106
    Not quite the same, but I wanted a toe ring... not finding any at the store so I decided "hey try one of the fancy rings you already own, and move it to the toe"
    It Worked!  Not with every item, and not always easy to fit, but a bit of tweaking x,y,z axis and a bit of x,y,z scaling and Toe Ring.
    Consider trying that with wrist or necklace products you already own.  You might get lucky.
