Deviney explosions - does it work as I am thinking?
Is this content what I think it is?
http://www.daz3d.com/rons-explosions
  • 7 Photoshop files at 300 dpi with 50 layers each (.PSD)
    • Bursts 2500x2500
    • Charges 2500x2500
    • Debris 2500x2500
    • Glass 2500x2500
    • Fire 2500x2500
    • Sparks 2500x2500
    • Smoke 2500x2500
  • Any Program that can open layered Photoshop files (.PSD)
the highlighted text above mentions --- 50 layers each.  Does this mean there are 50 layers included per type of explosions.
I need to sequence frames to create explosions in my videos.
If you know anything about this content  I would appreciate to read your thoughts
  • they are photoshop images to add to pictures as postwork, I doubt they follow any animated sequence
    if you want the latter I would suggest Hitfilm Express, its free and can render image series or video of its 2D and 3D effects for using on planes, billboards, popvideo  say in Clone well as composite into existing video.
    I do the latter as you can mask bits and render layers and use in it  too.
      • Bursts 2500x2500
      • Charges 2500x2500
      • Debris 2500x2500
      • Glass 2500x2500
      • Fire 2500x2500
      • Sparks 2500x2500
      • Smoke 2500x2500
    Yes, there are 50 layers per type.  They are not sequenced frames - some are similar but nowhere near enough to create animations with.  It is high quality but not what you are looking to create animations.
  • lenwilderlenwilder Posts: 188
    edited November 2016
    Thanks for the responses. I will pass on this content.
    Post edited by lenwilder on
