Save G2F figure as G3F Figure
What are the proper steps to load a Genesis or G2F figure, and then transfer utility the G3F rig...if you don't want to use Auto-fit? (for example, I scaled and translated the Genesis/G2F figure such that it looks perfect on G3F)
If I just use the transfer utility, after it is done, when I then "fit to" G3F, it snaps back to original scaling and translation. :(
I'm not following what you are doing.
Do you mean Genesis or G2F clothing on G3F using Transfer Utility rather than autofit? Do you have "reverse deformations" ticked?
Ah, if that is what you want then the Transfer Utility ignores any transforms - you would need to bake them in by exporting as OBJ and then reimporting, using the same preset for the options both ways.
Some of what you are looking for is addressed in this thread...
http://www.daz3d.com/forums/discussion/24093/transferring-morphs-from-genesis-to-g2m-g2f-and-from-g2m-g2f-to-genesis-now-with-clones/p1
