G3F iris problem
SertorialSertorial Posts: 962
edited November 2016 in New Users
Can anyone explain the white ring around the iris? Seems to happen with any iris diffuse map. More importantly, how do I fix it!
Thanks
Post edited by Sertorial on
  • BeeMKayBeeMKay Posts: 7,019
    In the shaping tab, look for the iris correction dial.
    thanks. tried that already. Doesn't fix the problem when dialled in either direction :-(
    Is that image a render?
    If so, check for a displacement map on either the iris or sclera...unless SubD levels are increased, for Iray, displacement maps will move too much of the mesh and 'override' the adjustment morph (too much large scale movement for the morph limits).
    hi. yes, it's a render.
    I checked, there is no DISP map on either the iris or the sclera
    Which character is this?  If her eyes were enlarged, the limits on the correction morph could now be too low...
  • SertorialSertorial Posts: 962
    it is Chiyo HD for G3F (by Raiya).
    I did try switching off limits on the parameters of the iris correction morph, but at extreme values (e.g. 500% it seems to move the iris inside the skull - which looks extremely odd).
    I have never seen these white rings around an iris before. Do you know what causes it?
    And what is the iris correction morph actually doing?
    The iris isn't attached to the eyeball...the correction morph is moving it in/out a little to keep it from intersecting/poking out/creating a visible gap with the eyeball.
    Here is the correction morph at zero:
    A -100%
    At 100%
    And at -7.1%
    Now other eye morphs and size changes, especially changing the size of the iris will affect how much correction will be needed.
    512 x 512 - 143K
    512 x 512 - 158K
    512 x 512 - 140K
    512 x 512 - 127K
    Post edited by mjc1016 on
    Thanks. That's helpful. Maybe I had increased the size of the eyes (I need to check that).
    But it would surely help to avoid this problem altogether if the iris map went right to the edge of the iris disc! I am not sure why there needs to be a bit of white space around the edge. It's just asking for trouble! ("I know, let's introduce a problem that we then need to add a correction morph to fix"
    Nope. It wasn't the size of the eyes either. No amount of morph fiddling fixed this, so eventually I decided to edit the iris diffuse map to bleed the brown to the edge of the iris (God knows why the PA didn't do this!)
    Admittedly, there is now a slight black ring there for some reason, but it's certainly preferable to white!
    1589 x 905 - 305K
    1000 x 1000 - 1M
