Shape Shift for Genesis 2 Male(s)
OKCRandy
Where are the documents for this and other resources sold at DAZ3D? Most of them do not include documentation and how to lessons.
OKCRandy
Did you look in the Shaping pane?
Ok I found the shaping pane but there are only characters there nothing that I can find for Shape Shift
Hmm, they are a bit spread around. You'll find them in the Shaping tab under the part of the body affected:
Upper Body - Real World - Shape Shift
Arms - Real World - Shape Shift
Waist - Real World - Shape Shift
Legs - Real World - Shape Shift
Feet - Real World - Shape Shift
They can also be used through the Parameters tab in a similar location.
Thank you and bless you. Now if I only knew the proper way to save a custom chatacter where they do not have to have shape shift I would be good to go. I will not buy any more products like this that do not have good instructions. The developer should assume that the end user does not know anything on a product like this.
You're welcome, glad to help.
Funny thing about this product is that the ReadMe has much less information than the ones for Shape Shift for Genesis and the G3M and G3F versions. Those versons all llist exactly where to look in the Parameters of Shaping tabs, so it's more a blip than the standard for that vendor. Perhaps a CS ticket requesting better information in the G2M Readme (and the G2F, which is identical) would be worth doing, if you have the time or inclination.
