How do I? Genesis 3 OBJ for morphing
I want to create a Genesis 3 OBJ for importing into modeling software like Blender or Wings or ect.   Basically I want basic Genesis 3 female and male so I can make my own morphs and then be able to load the new morphs into Genesis 3 figure.
    Load just the base model, don't add any morphs.  Then go to the Parameters and turn the Resolution to Base.  That should turn off any subdivision.  Then export...
  • TSasha SmithTSasha Smith Posts: 27,350
    Thanks.  I was forgetting the resolution part. Guess it is time for me to go to bed.
    edited November 2016
    Also turn off the mouth HD and navel morph that are on by default before exporting.
    Post edited by SickleYield on
    Where are those morphs?  I am unable to find them as I need to go to bed ASAP
    If you select Currently Used in Parameters, they'll show up...
    The good thing is, once you export a set, you won't have to do it again.
    Are there any starter suits for Genesis 3?
