Animate blocks sooooo tiny
ok, I keep forgetting to ask this.
I have tond of Ani blocks, but it's so fricking tiny at the bottom of the screen, that I have no clue what the text is in the blocks to see what it is.
The menu itself is already tiny and hard to navigate at the bottom.
Is there an easier way, or am I just stuck with it?
you can mouse over them in the content library too and drag them to the animate timeline.
.... never thought about that one..
Was looking on You tube, and there it was much bigger, but saw that it was all Daz 2..
Unless it's the theme that i am using.. I using the dark one. (see all my other screens with questions about stuff)
Thanks
The screen resolution you are using affects the size also.
I use my computer in the living room and my monitor is about 3 feet away from me (as I sit in my recliner
), making it difficult to read if I use the higher resolution settings, so I use 1280x960 so that everything appears larger.
