Need help tracking down this set! -- SOLVED
Knittingmommy
I used this in a render when this set first came out. I have it. I just can't find it. I don't have everything back up and running after a computer crash so not everything is installed again. I don't remember the name of this set:
Can anyone help me out? I have an idea for a render and I want to use this. I have no idea why I saved this render with the name BubbleTree as that is NOT the name of the set. My only excuse is that it was before I got smart and started saving renders with actual set names.
Post edited by Knittingmommy on
It's Art collaborations and it's the Enchanted Glade http://www.daz3d.com/the-enchanted-glade
@Sickleyield Thank you VERY much!!! :)
@Chohole Thanks SO much!!!! :)
Yes that is the set :) If you need anything when you go to use it, please let me know and I can't wait to see what you create
@DAZ_ann0314 Thanks. I found it in DIM and got it installed. I just loaded it up to make sure it loaded okay. No problems so I'm set to get started. I'm working without CMS at the moment with my install as I still haven't figured out how to get CMS working in my Linux box yet. So, finding things can be a little tedious at times, especially when you can't remember the name of a set that you know you have! :) I'll let you know when I put it up in my gallery when finished. :)
