How to animate HDRI Dome rotation?
I'm looking to create keyframes for rotations of the HDRI dome. I only know how to set this in Render Settings, which cannot be changed on a per-frame basis.
  • might be easier to parent your whole scene, lights and camera to a nul and rotate that.
    Definitely...the 'dome' is not 'physical'.  It doesn't have geometry or anything to be able to keyframe.
  • nonesuch00nonesuch00 Posts: 18,762
    Doesn't that new spherical camera in the latest DAZ Studio Public Beta do a 360 render? Someone from the forums, Madcatlady or something like that did such a render and uploaded to youtube and in the top left hand corner are 4 arrows that go up & down, left & right for a 360 view.
  • those arrows come from injecting the mp4 with metadata so youtube embeds it as a 360 video
    I have a thread on it in the Carrara forum
    http://www.daz3d.com/forums/discussion/78861/360-vr-youtube-video#latest
    Thanks, I like your videos.
  • ToborTobor Posts: 2,300
    Looks like dome settings aren't recordable in the animation timeline... which would be a bug. You may want to send in a ticket to Daz about it. If a setting can get stored in the scene file, it should be recordable in an animation timeline.
    I don't use animation for such things, but I will use a single file to store multiple "frames," like different camera angles and poses. It's a real PITA when settings don't get saved for a frame, should you need to go back to the file for an update.
  • Looks like there's a work-around. Instead of rotating the HDRI dome, rotate everything else instead. Just group the camera and the objects involved, then rotate the group on the Y-axis. You may have to adjust the position of the Y-axis in Joint Editor so that the group remains in the centre.
