Stephanie 5 Question...
wancowwancow Posts: 2,708
I'm a little unclear on the Model and Curvy morphs for S5... they ARE designed to be used WITH the Base Stephanie 5 morph active at a value of 1, right?
  • thd777thd777 Posts: 945
    Correct. They are designed to be used on top of the base Stephanie 5 morph. However, they can be used without, the look you get will of course differ form the intended one. Most noticeable the scaling will be very different because the S5 is much shorter than base genesis.
    TD
  • larsmidnattlarsmidnatt Posts: 4,511
    S5 curvy works well on most women ;) I love the bit of shape she adds.
    This is interesting. To acheive the intended stephanie curvy look, is the dial for stephanie supposed to be all the way up? I agree about the steph curvy morph. that is a good morph, lars.
    I am curious, because with other figures.... For example some M5 morphs, if you dial M5, and the morph he can look kinda freakish.
