Adding to Cart…
Hey divamakeup, I've been admiring your avatar for a while now, what figure/skin is it?
I have noticed the Sorrow Hair seems to get abnormally bright in certain scenes.
I'd chalk the morphing issues up to beta weirdness.
dim first then connect have few things connect only and not everything fully installs via dim also few times I used up my monthly internet reduced to dialup speed and stuff would not download install via dim but could via connect. I let dim and connect install to default locations. This is a new computer I bought with the 1080 cards so wanna make use of them why I'm happy the beta lets me use them and the other copy of daz on my computer is the current full version which can't use the new cards in a way it's a pity that warped effect isn't an actual morph be pretty cool if it was would be good with the Rain horror character skin and if she also had an unhinged jaw morph so you could have one of those really big mouths you see in a lot of ghost movies now
tried to make use of it so with Alice I gave her Rain's horror character texture and the scared one that is Rain's body head morph with Alice's texture
That's turning lemons into lemonade!
Do you have GenX? I wonder if you transferred her morph to G2, and back again, if it would still have those strange issues.
Also, did you say the morphs did strange things in your full release version, too? Is that using saves created in the beta first, or were those from "clean" scenes created in the full version first? What I mean is, if you use the full release version, and add a new character into a scene, does it still have those issues? If it works right, save that scene in the full version. Then try loading that scene in the beta for rendering. Maybe that could be a work around. Build scenes in the full version, render them in the beta so you can use your Pascal card.
Only time I've seen similar was when I'd forgotten to do 'something' when I was applying a morph; it is was to do with ECC. Sadly I don't remember what, but perhaps it will point you in the right direction.
Although it it's working in other versions but not this, it might not be product related.
It is easy to look at an issue and think it is the problem when in fact its a symptom of something else. Just because its causing a problem doesn't make it the problem - sadly at times when trying to track bugs and errors down.
happening in both full and beta versions, new and old scenes saved, but if I load up a different charcter first scene or few after and delete then add her and pose she's fine just seems to be happening to her if she is the first one/scene loaded bought her when she first came out and didn't happen then and used her a few times too in the past. Tried uninstalling then redownloading didn't make a difference though in some poses her eyes popped out like in Total Recall but like I said if I don't use her first she's ok did happen to some of the other SC gals too at one stage but they seem fine too and Rain has beeb perfect little angel. Have had a lot of updates maybe something clashing but haven't seen any other threads of anyone having this happen
